M
Hey gang, I'm trying to get my head around everything with the special SnoX race engines like the 726, 727 and 797. Please educated me here; as best as I can tell, these 3 use an 85mm bore with the 726 & 727 using the stock 64mm stroke and the 797 uses a 70mm stroke.
Interestingly enough, the new 600 race engine uses a 70mm stroke and the 800 CFI is 85x70. I'm a bit ingnorant on how "stroke" a motor; is it simply installing longer connecting rods to go from the 64 to 70 mm stroke? Is it a completely different crankshaft, with taller journals? Does an engine with a 70mm stroke use taller cylinders than a 64mm stroke engine?
What exact components did these race engines use? 800 Big Block crank with the small block cases heavily machined out? Cylinders? Can the 600 small block cylinders be overbored from 77.25mm to 85mm and re-nikasiled? I'm wondering if the 800 CFI components can be fitted to the 600 VES and HO cases; that would be one smokin setup...
