I'm trying do decide if I have a problem and how soon it may need to be addressed. I have an 08 800 dragon with about 850 miles on it. the 2010 update was installed around 400 miles ago. i pulled the exhaust valves today to have a look and am noticing some of the coating has been worn though on both pistons (most notable at top and bottom of pistons). there is light scuffing on the pto side except for one hard scratch in the far left view in the pto piston, about where the exhaust valve may make contact with the piston. it is most pronounced in the middle half of the piston when turning the engine over.
is the coating wearing off typical on these updated double ring pistons. is it due to increased friction and heat from a second ring?
so, i'm starting to wonder if i need to pull it apart and have a look. i'm thinking i need to have the cylinder skirts looked over for cracks and possibly renicked if it's out of spec or damaged.
i'm pretty new to two stroke engine work and only know what i've read here. so, what would you do if it were your sled?
