Perks Balancing
It's time to respond you all know there is two sides to every story !!! First to the video by the polaris owner. That sled was witnessed by 6 other people besides him and I and it didn't leave my shop looking like that.
How many miles on that polaris? 1312 miles, all you polaris owners know the life of a polaris 800 (crank breakage SOMETIME BEFORE 2500 MILES).
How did the clutch spin before we worked on it? His answer was " IT LOOKS ALOT BETTER IT'S NOT JUMPING NOW"
This was only the second 2009 polaris 800 Dragon that we had worked on with this new balancing possess and he knew that up front.
Who referred him to us? His friend with a 2012 Etec and what did Perks do for him. 400 RPM INCREASE, IT OVER REV'D AND HE HAD TO CHANGE ARMS IN CLUTCH. NO VIBRATIONS IN ENGINE PARTS AFTER IDLE (2000 to 3000). Indydan since you know everything about everything how much increase in HORSE POWER IS THAT?
Yes, he had a strange LITTLE vibration on the mag side of the motor. Which could be several different things. A bad bearing, one of the throws out of phase, and yes maybe the air flow of my mag. rotor.
He picked up the sled on a Friday and I didn't feel good about his attitude toward my service so I called him two days later. Mon. and apologied if I sounded up set. And told his answering service that I would look at his mag. rotor (in which we have since perfected his has to much intake (air flow) which caused that strange vibration. I also offered to balance his 900 polaris for FREE!!! We have 6 Polaris 900 out in the field and all 6 have increased 200 to 400 RPM and they are no longer replacing belts on just about every ride.
Now to the 19 days in my shop. I didn't here him mention or read anything about my older brother dying of cancer and the days I felt I needed to be with him during that time. And then pasting away about a week later. I'm not going to apologize for that.
I'm glad my product is not on his sled so when the crank breaks or some other thing goes wrong he can't point fingers at PERKS.
We oil the cylinders when running the motors and we only run under a 3 horse power motor for less then a minute each time.
Even after all that and the disrepect showed to me I would still work on his sled for FREE to make him happy. The issue on his sled is not BALANCE it's air flow - it should have no intake air flow.
LET ME MAKE IT CLEAR - I WILL NEVER RUN AND HIDE OVER ANY ISSUE THAT INVOLVES PERKS SPIN BALANCE OR POST ON SNOWEST OR ANYWHERE UNDER SOMETHING OTHER THEN "7PERK"
Indydan the owner of that TRA clutch with 39 GRAMS in the front end of the clutch responded months ago that it had all new parts in the clutch assembly. He couldn't be happier with the balance job.
I will respond on all the other issues in the next few minutes. This is all I'm going to say about that Polaris 800. That sled was not filmed by him in my presence it was doctored up.
