Lazy 900 RMK
Apr 10, 2009
32
I have a 06, 900RMK that tweaked while cruising in the mid range. Compression 105/75, Has any one else had this problem? I suspect a complet
rebuild is needed.
jafraune
705
72
wyoming
Any addons to the sled??? Pipe maybe? Check intake boots for cracks....lots of false air get through there and cause a lean burn down.
N
Nelson
1,496
73
48
39
Libby, Montana/Elko, Nevada
More than likely it won't need a complete rebuild unless you want to spend the money, probably just a top-end. You should check the crank runout to be 100% sure.
What mods do you have done?
Throttlebody boots do crack out which will lead to a lean burn down, the o2 sensor is in the boost box or in the air box (SLP) and will not detect.
H
High Velocity
1,050
497
61
Hinton, Alberta
Actually, there is no oxygen sensor incorporated into the Cleanfire systems. They have an intake air temperature sensor, exhaust temp sensor, coolant temp sensor, barametric pressure sensor (built into the ECM), detonation sensor and throttle position sensor. Problem could have definitely been caused by a bad throttle body adapter as previously mentioned. I also wonder if the throttle position sensor could cause this issue if it just leaned out the engine in one throttle position.
donbrown
1,017
Los Angeles
rebuild is needed.
If this compression is correct 105 and 75 ... the cylinders are in immediate need of a rebuild ... or you're gonna put a hole in the bottom of the case.
N
Nelson
1,496
73
48
39
Here's a perfect example of punching a hole threw your cases. No loss of compression or warning until the pistons broke.
2006 D9 MAG side
06900D_12.jpg 06900D_13.jpg 06900D_14.jpg 06900D_15.jpg 06900D_16.jpg 06900D_19.jpg
Apr 10, 2009
32
Definitely a heat seize, mag side scuffed and pto side has some wash,no broken rings. One boot has some cracks,nothing serious. Normal oil consumption. Machine has 1960 miles,SLP can and high flow air kit.
donbrown
1,017
Los Angeles
A boot with any cracks is serious because it creates a lean condition and scorches the piston and creating compression loss and eventual piston/ring/wall failure.
