guys i need some help with this failure. this happened last winter, just getting around to fixing it now. the pistons are from a 2012 polaris 800 SB assault with 1800 miles on it. the piston that failed was the Mag side, the other piston is from the PTO side obviously. here are the events that led up to the failure. sled ran flawless until the failure. the sled was warmed up to 125 degrees, like it has before every run. sled went for 1.5K and died. pulled rope fire up again went for 100 ft died and is now locked up. towed back to trailer and loaded back up. now when taken apart on saturday was expecting to find both pistons screwed up. we were assuming a cold sieze, and were are little puzzled when we pulled the pot off to find one piston severly scored and the other piston normal. i did not get a chance to takes pics of the pot, but it was not pretty from what i was told. looking for opinions. the plan now is to pull the engine and go thru everything and start from the ground up. thanks for your help!!
