GEN II, our home built snowbike project
M
Jan 6, 2015
1
37
Good day. I am very impressed with your work. After reading I had a desire to try to make a snow bike. I have a few questions for you. Can we talk?
27,447
JUST A NOTE
In post #1 there are 54 Embedded Images.
Only 5 of them are being displayed, and those are HUGE for this forum to display!
The other 49 all point to a URL that says "Content not found"
If the original poster would like everyone to be able to see those images, it would be best if he uploaded them directly to his SnoWest Photo Album, and then embedded back into this thread
swedenturbo
330
397
Sweden
Sorry all visitors here for not showing you all photos of the buylid process. Sad to see that pics are not shown.
Many photo URL's in this thread was linked from our snowbike build group on Facebook.
FB has unfortunately changed most URL's
Since these photos pics didn't show, all recent post were made by using Tapatalk. Seems more reliable in this matter.
Christopher: If I want to edit old previous posts with new photo URL's, is this possible?
swedenturbo
330
397
Sweden
Reposting previous post, now with working photos
Hi guys!
This gonna be a long first post but I´d like to share our progress so far. Hopefully I will post you more as we go...
I think photos tell more than plain text especially when I work hard to write in english ;-)
Hope you enjoy my pics ;-)
Seen lot of DIY snowbike kits here, great work guys!
2 years ago, me and my buddy built two Mountain horse replicas, well it may look like a copy but we designed it only from pictures seen on the web.
We didn´t dare to build the suspension so we used a MXZ skid. An easy way out but doesn´t work as well as the original suspension.
Here's a link to some photos of our first build.http://www.snowest.com/forum/showpos...79&postcount=2
We have ridden with it for the past two years an it works pretty well.
There are some things we would like to improve. Instead of motifying existing kit, we took the decition to build new kits.
Things we saw could be improved:
1. Less weight. We aim for a weight reduction of 15 kg, hopefully more.
2. New suspension. The build used a modified MXZ bogie , greatly oversized snowmobile suspension that is basically for hard trail riding. Instead we plan to build a pure snowbike mountain suspension . It will be much lighter and designed just for snowbikes, not sleds.
3. New track. Last track was 3050mm with 44 mm lugs. The new build will use 3460 with 59 mm lugs. As we ride 96 hp turbo bikes, we believe they can pull that track easily ;-)
4. New tubular frame. The first build had steel tube with 2 mm thicknes, way too heavy. Now we´ll use 1,2 mm thicknes. A Swedish steelquality called SSAB Docol. Its reminiscent of chrommolly but promises to be easier to weld and less risk of cracks.
5. Movable jackshaft. We had some issues with the tension pulley on the motor chain. Moreover, it has been difficult to get the right chain tension, especially with some gearings. By being able to move the jackshaft equal when tightening the chain on a motorcycle rear wheel , we will be able to run any kind of gearing, less parts and also lighter .
6. 6005 bearings with updated custom made housings. Less weight
7. A slender and more sturdy chain case that reduce the risk of hitting rocks and stubbles.
8. Newly designed tunnel panels that are more slender and exposes the track so that any stubs or rock collisions are hit by track and drive wheels and not the front tunnel area and chain case.
First challenge is the design of the bogie.
We will try to design a suspension similar as EZ ryde. Believe that it is passable for these machines with good options to adjust ski pressure and suspension stiffness. In addition, the EZ ar well known for its good powder snow properties.
Started by cutting the 59 mm track. A really crappy job, but what do you do? Smokes and smells like hell but at the end a good result.
The reason we start by cutting track is that we want to strip that is left.
With it, we will make a simple mockup of the suspension to try different geometries.
As said the GEN II will have a new custom designed rear suspension.
We begin with an analogue "drawing" to test geometries.
By doing all out of wood and chipboard we can easily test various attachment points and see how it affects the suspension travel.
We're onto something, but need to adjust some attachment and get a slide function on the swingarm rear mounting.
Unfortunately, this type of bogie has an "impossible geometry" of track tension and, therefore, the sliding function combined with the front shock will push back the rail
therefore tensioning the track. Have done shockdummies with the correct length and stroke.
We also printed the blueprint from our first build at a scale of 1:1 to get some known references.
That way we can see how our analogue drawing will fit the new design.
We try to be thorough with the design and all the drawings.
This way we can order most parts pre-cut with almost every drilling done.
The first build was more or less a replica build of original Timbersled Mountain Horse. Here´s the new design of the tunnel panels.
Looks similar to the previous build but is completely redesigned.
attachment.php
The bogie will remind EZ-Ryde's design.
We believe one advantage is that it is completely uncoupled and enormously lighter than Ski-doo SC4 suspension.
Also, the front of the rails will hopefully flex in a way that can be beneficial on snow bikes.
The rear travel is more than 400 mm.
Here we test the suspension travel more theoretically.
EZ ryde on sleds have a swingarm that can go almost straight back. On a snowbike the swingarm has to move into upper bogie wheels due the narrower the track.
If the swingarm would go straight back without a waist, it would be in the extreme compression hit in the bottom of the upper bogie wheels.
For that reason, the swingarm to get a little odd design.
forum
This image shows better how the upper bogie wheels sit in relation to the swingarm.
Yes, finally all the laser pre-cut parts and done! Here we go! Many parts .... All this for two kits + one set of welding jig.
These parts are cut out of 3 mm steel, made for just templates for jigs.
Here you can see some of the design in the movable jack shaft. As the shaft are moved, the brake calipper mount also moves.
There are some differevces in the design between the first build and the GEN II. Side panels are of a more modern straight lines and kind of duck tail ;-)
Starting to work with "the mother of all jiggs". Spent some time on it but we will regain that work later on.
This piece is thick and heavy and stands up against anything! Laser cut drilling template facilitates that the attachment points will the right place.
May seem a little over-ambitious, but but it will help us in the long run ;-)
I would highly recommend to order precut jig templates. We feel confident that all the measurements are correct and that it is straight.
Tried some notching with the mill.
Lathed and milled the upper bogie wheels. They will have a diameter of only 100 mm.
This time, we ordered pre-bent tubing to tubular frame and swingarm. The drawing was of great help to get all the measurements and angles right. The swedish dragracing frame company ME-racing has done a good job of bending. Fits correctly!
Ordered the front suspension FOX Float shocks. They are originally to a Honda ATV for correct length and stroke 330 by 259 mm.
Lathed and milled hub of the brake disc.
Made the rear axle.
A little start with the tubular frame. The fit seems to be better than expected.
A little work left on the drive shaft as we await delivery of the drive wheels. The gearing may be a bit unusual : 14-19-18-16 give a final speed of 91 km / h at 8,500 rpm at 5th gear. 6th can be considered as a cruise gear.
If gearing will be too high , we can easily switch to 17 or 18 tooth on the drive shaft .
We want the sprockets to be as lightweight as possible .
Started with a simple drawing to get the right dimension spacing of holes. Want to be a bit careful with the holes so no strength deteriorates.
"Spoke" thickness is 8 mm in small, ranging between 9.1 and 5.9 mm on the large gear with large center hole.
Partition table is a big help to drill the holes with correct spacing.
The sprockets seems to be as strong as solids. Total weight of all sprockets incl. clamping sleeve on one sprocket was 1,007 grams.
Here is the drawing on the drive shaft and jack shaft .
The shafts will be drilled with 16 mm long drill.
8" Slydog rear wheels weighing 350 g. Of course in KTM colours ;-)
forum
The work with the first tubular frame proceeds. A little work left before we can remove it out the jig. It will be interesting to see if it warped after welding.
Notchning of the rear connection of the arch was improvised. We clamped the pipe at 45 degrees and then tilted mill head 67 degrees for it to be the right angle. The results exceeded expectations.
On this kit we ordered precut base plates, of course, with lightening holes.
The holes in the jig was made ​​that we can turn it upside down and weld the bottom without having to remove the frame.
Anything to prevent warping when welding.
The last build we used a cut off Ski-doo REV-spindle in the lower part of the ski bracket.
Clearly the easiest thing to do for the home builder but this time decided to make it a bit more advanced made out of billet aluminum.
Started by making a drawing to get the coordinates and angles .. The material is a circular block with a diameter of 100 mm.
Lots of material to be milled ...
Round feeding table made ​​it easy to get the right angles. Hole drilling seemed to go as planned.
The outer round part of ski bolt bushing was kept while the rest was milled around using circular feed table.
Edit:
Forgot to upload the final overview drawing:
More to come....
<!-- / message --><!-- edit note -->
swedenturbo
330
397
Sweden
CNC machined housings required little further milling, drilling and tapping but now they're finished!
This bearing housing will sit on jack shaft closest to the chain case. Has dual 6005 bearings as this will be under double loads. Partly from motor chain and chain in the chain case. The saved "block" is where the tensioning bolt will push.
The back is milled to run in the slot hole in both tunnel section and the tubular frame.
Drive axle housings have no locking ring groove as tunnel panel holds bearing in place.
Here you see the principle of chain tension by moving the bearing housing.
A small drawing error. The radius of the hole in the tunnel panel does not match the radius of the bearing housing. Gotta grind this to get it right.
swedenturbo
330
397
Sweden
First frame completed. We are pleased that it hadn´t warped during welding and was completely straight. The jig must have prevented this in a very good way. We had predicted a weight around 5 kg. A little disappointing that the scale showed 5.4 kg. However, we believe that this frame is stronger. The reinforced swing mount sleeves adds a little weight.
Here you see the laser cut template which is temprary bolted to bearing housing mount plate. This way we can ensure that it´s welded in exactly the right place. Same template will be used when we drill the mounting holes on the tunnel panels. Just to ensure that both bearings will be alligned correctly.
<!-- / message -->
swedenturbo
330
397
Sweden
We try to make every single part of the kit as light as possible.
Drilled the 27 mm drive shaft and and the 25 mm jackshaft with a 16 mm long drill bit. If there has been a 270 horsepower engine, the shafts probably wouldn't hold up but with a 50-100 hp snowbike it´s a different story.
We plan to temper all axes to further increase the safety margin.
Machined a plug in 16 mm the hole at each drillhole end of the shafts.
Then drill a smaller hole and tap for a M10 bolt so we can pull the whole assembly together at each ends of the shafts.
Machined the plug by two hundredths of a milimeter oversized for press fitting.
The plug welded, shaft end machined and tapped.
Right side if the kit (shafts turns clockwise) is threaded M10 fine left hand thread. Left hand threaded should hopefully reduce the risk of it coming loose, even without Locktight.
Testing assembly of bearing housings, brake caliper mount and caliper.
As the pic shows, the bolts are too long, need to fix some shorter....
Here´s the drawing of our shafts.
swedenturbo
330
397
Sweden
After a lot of TIG-welding the frames are completed. They didn't warp after welding so the theory worked in practice.
The strut replacing the rear shock completed. First build, we had a solid 30 mm aluminum rod. This build we try to make it as light as possible by making the strut hollow. Almost exactly 0,2 kg less. Now weighs exactly 0.5 kg. Worth the effort? Well, maybe ....
A drawing of the strut.
30 mm rod drilled with 22 mm drill bit. Welded ends machined and threaded.
Bent the side panels of the ski mount. We will produce 4 units, 2 ski mounts per kit. Good to have an extra if we'll unlikely wrecks a mount.
When you have no bending machine, just fabricate your own for your tool press
Works really good!
The cardboard templates gets the bending angles right.
Machined axle sleeves. The edge goes inside the aluminum panels, welded both from the inside and the outside.
Made a wooden template to bend the strip that will form between the side plates.
Welded inside before the strip were attached.
forum
First test assembly of the side panels and tubular frame.
The laser cut template was also used to align mounting holes for the side panels. This we think this is crucial of the alignment of chain case bearing housings.
swedenturbo
330
397
Sweden
The work om our build proceeds.
Machined bushings and shaft to the front attachment of the swingarm.
The first drive chaft we made of hexagonal rod was sent to the scrap box. We have discovered that the steel quality was too low and threatened to break.
Machined a new drive shaft. 32mm shaft of machine steel in good quality. Shaft diameter 27 mm and drilled out with 16 mm long drill.
Skid and suspension completed.
Rail extensions are nt light weight or pretty. Will run these during testing.
I have some longer rails from a Nytro that I will test when the kit is completed. I Think the Nytro rails has a better design for the LT application.
ST rails and track might be a nice option for the spring season!
Made ​​the chain case reinforcement rim. GEN II will have a different solution to the chain. A 10x30 mm aluminum rim bolted from the inside of the tunnel. This will stiffen the tunnel panel and we think this is much better compared to the previous solution on the first build. The chain protection lid will only be a thin sheet that covers the chain.
A laser-cut folding template made bending easy and accurate.
Both sides of the rim was milled flat.
Another drilling template makes the holes will line up correctly. Tapped for M6 screw with countersunk head.
The rim will have a small notch so that the lid will be flush.
Test assembly. Only the middle bolt hole is pre-drilled in the tunnel section. This is to be able to adjust the position of the other holes that is bolted to the tubular frame and the jackshaft is aligned. The previous build we had some problems when the frame warped during welding. The predrilled holes didn't line up and we had to grind them up to get it right.
GEN II will tension motor chain by moving the shaft.
The caliper is mounted together with the bearing housing so this will also move with the jackshaft.
<!-- / message -->
swedenturbo
330
397
Sweden
First test assembly of suspension.
It may look tall standing on the workbench without track but in fact it is just 40-50 mm taller than our previous build.
Tunnel is shorter than the bogie and will have a snow flap in rear.
swedenturbo
330
397
Sweden
Track mounted
Some comparison pics with our previous build.
The only part that is not optimal is the MXZ rails. It's 9 centimeters (roughly 4") between the tip of the rails and the drive wheels. Redrill and move rails forward will result in a steeper attack angle.
The biggest problem is not about the risk of stab, that could be solved with anti-stab wheels. Rather, it is that the track that doesn't have support from the rails . This increases the angle of attack in this area.
Put my Nytro Mtx rails in front. Have flatter bend, you can get the tip closer to the drive wheels. Should work out really well I think. After some test runs I will probably switch to these rails instead.
Put the uncompleted track kit on a simple scale, ie a margin of error.
50.5 kg
4 kg of other parts that are not mounted on the kit. Also have to add another half of a chain at 0.7 kg. Total weight should be in round 55.5-56 kg or 122,3 lbs. That seems to be pretty good for a LT with 59 mm lugs.
swedenturbo
330
397
Sweden
A lot of details on the turbo kit must be adapted and redone as the new track kit has some design differences from my previous kit.
The pipe to the plenum must be altered because of new location of the brake disc.
Because the tubular frame is 10 cm shorter, connection to intercooler must be modified.
Gets tight but it should work.
Will cut off a bit of the outlet from the turbo so the rubber bend will fit.
swedenturbo
330
397
Sweden
Made previously a set of ski mounts that was a straight off copy of Timbersleds.
After a ride in mountains we saw a tendency to bending/flexing. Not due to poor design but most likely because it was used fairly short time after welding. Aluminium should rest about one month at room temperature to regain its strength after welding, at least that's what we've heard.
Well worth thinking about for those of you who weld your bogie rails!
Testing a different design that does not require welding.
In addition, a sleeker and more modern design, very similar as UFO:s ;-)
8 mm water-cut aluminum panels.
Chamfered edges. Has no practical significance but looks good.
Milled the edges with a router mounted under an old saw table.
The mill head has a ball bearing that rolls on the edge.
Powder-coated aluminum panels.
Machined spacer sleeves for axle.
M8 stainless steel countersunk screws
swedenturbo
330
397
Sweden
Test assembling gears and chains
Carbon fiber is a little fancier?
Testing the fit of the water-cut carbon fiber chain case cover.
The real thing and not just a sticker. :face-icon-small-win
Tight fit with very little adjustments.
Glued plugs carbon fiber tube with epoxy glue
forum
Made a plastic cover at the bottom of the chain case
First test ride, awsome!
Feels light, smooth and nimble in powder.
On trail it was a bit too hard. Have to try out some different damper settings. 100 psi in the rear shock proved too much.
With a little more time and testing will probably get it even better!
Did not have time to mount TCV valve so I have run the same boost as last year: 0.5 bar. Despite low compession piston I didn't feel any difference in low rpm and NO LAG. It charging surprisingly early.
For next weekend hopefully I'll get the valve in place and raise the boost slightly. Should provide an additional 10-12 hp.
Here's a short video from my buddys bike.
<EMBED type=application/x-shockwave-flash height=385 width=640 src=http://www.youtube.com/v/KaeOHnsFglE>
</EMBED><!-- / message -->
<!-- controls -->
swedenturbo
330
397
Sweden
As you know, building a prototype things doesn't go as planned.
As we go we see some minor improvements.
Front shock mount was not as strong as required.
No problem, back to the drawing board :face-icon-small-win
New design that spreads the load on to two shafts.
<!-- controls -->
swedenturbo
330
397
Sweden
The kit works awesomely well! Wery pleased of how the suspension works.
Still some improvements and modifications to be made as predicted:face-icon-small-ton
Previously our design had dual bearings closest to the chaincase on the jackshaft. The theory was that two bearings would have double strength that would improve the longevity of the bearings. Unfortunately, that did'nt work as planned. Our tests showed that all load went to only one bearing and the other showed a lot of wear.
We have redesigned the housing to utilize a single 6305 bearing. A C3 rated bearing with wider tolerances will hopefully handle misallignements better.
The skid is rebuilt for short track. We have installed a 3050 mm backcountry X2 track with 51mm lugs for spring conditions in the Mountains. It will be interesting to feel the difference between LT :face-icon-small-win
Got some issues on the last ride when the upper shaft to the rear shock was bent quite dramatically. We could ride the next day so it was'nt an urgent fix but must of course hade to be improved. We suspected that this could occur with aluminum shaft but worth a test. Instead a 22mm 2541 steel shaft was installed, which will have a high yield strength quality and considered to be strong enoguh.
Lower shock bracket proved to be too narrow. Chafed against the lower end of the damper rod as the bogie flexes laterally at the front. Beveled the inside of the brackets so it does not happen again.
swedenturbo
330
397
Sweden
You might be right Raveous, bottoming limiters may be necessary.
Our theory is that the shocks comes from a sled front suspension. These suspensions usually doesnt have bottoming limiter. The shock takes the load all the way to in the end position.
I think these Fox have built in rubber damper or I'm wrong. Either way, Fox is quite progressive and bottoming is unusual with the right air pressure preload.
My longest horse run so far, 167 kilometers. From Vuoggatjålme to Sulitelma Glacier and back. Worked fairly well and quite fun trail riding. Problems with hyfax overheating, they where completely worn out. Strange as it mostly wasnt icy or hardpack, rather fairly fresh powder on top. Ice sratchers or better quality of hyfax is perhaps the solution. The new 121"short track cogged over (maybe swenglinsh) pretty much. Gonna try to move back front lower shock mount that it stretches the track more.
If this doesnt help maybe nonslip drivers is the solution. Due to the high roll resistance because of hyfax overheating, 10 liter of extra fuel didnt take me all the way. Borrowed another 2 liters to take me home.
<EMBED type=application/x-shockwave-flash height=385 width=640 src=http://www.youtube.com/v/K5WUuG15D5s></EMBED>
New nonslip drivers has arrived.
Machined and milled a new drive shaft adapted for nonslip drivers. Hexagonal part comes in a different place compared to internal operating wheels.
After Easter ride overheating problems on hyfax i thought I should test fit ice scratchers on the ski. Have no idea if it works. There is risk that it becomes heavy controlled or tend to strive go straight ahead.
Maybe not the neatest design or construction but well worth a test. Not much time spent on these....
Putting scratchers on the rails, theres a risk are that they may get tangeled in the track when sidehilling on hard snow?
Scratchers in up position.
