Hi,
Polaris 2012 RMK 800
I just removed the cross shaft from the crank case and the small black rubber seal spring was facing the gear mesh cavity .
My 2004 service manual says that the small black seal spring should face the installer , I interpreted this as facing outwards towards the water pump impeller .
Can someone post out of a newer service manual the correct orientation or post with the utmost certainty the correct orientation of this small black rubber seal .
Thank you all in advance
