C
So I got a greaseable oil block off plate from cutler performance, and I'm wondering if you leave the old oiling sleeve in or remove it when you put the block off plate in
Yes you need the sleeve, it supports that end of the shaft. I fingered some grease in the cavity first and pushed the sleeve back in then fingered some more grease in, cleaned the sleeve plate and then the plate with some grey gasket.
If I remember right with that one cutler wanted you to cut some slits in the sleeve for grease to get thru.
