Cool Tools for 850 Doo's
M
Dec 4, 2007
273
94
Red Deer, Alberta
Thought I would share the tools I found for the 850 Doo's.
First is a cool tool for compressing the pDrive clutch on the 850's, for easy clutching or maintenance.
the second is a must have for your Etec tool kit.
Check them out
Trashy
69,549
7,301
Sherwood Park, Ab, Canada
The spark plug tool looks interesting, the pics on their website aren’t the greatest and it took me a minute to understand how it worked.
Have you tried one yet?
M
Dec 4, 2007
273
94
Red Deer, Alberta
Yes, it works great.
here are some better pics from Extreme vents site.
Wapow
515
371
I bought that spark plug wrench but haven't tried it yet. Wondering how you get the mag side clip on the plug wire snapped shut without pulling the secondary?
snowpatrol
46
Puyallup WA.
Check them out
you better buy several of those pdrive tools. i used mine twice and i already bent the crap outta the backside arm. it is worthless now!!
E
Dec 19, 2007
73
75
18
Mine did the same, just put it in a vise and push it back to the right shape. Great idea and it does work but could be made from a stiffer steel. Pushing on the sheave while levering the cam down will help not bend the arm. It also has a bit to do how smooth your clutch moves, dirty clutches take more force to compress...
C
caper11
2,056
2,178
Northern alberta
Kinda sounds like user error, or the arms are loose and not set correctly when the torque is applied.
Trashy
69,549
7,301
A quality tool shouldn’t bend and stay bent. Some flex is expected, but it shouldn’t hold what is called a “permanent set” after minor deflection. It is probably just mild steel.
C
caper11
2,056
2,178
Northern alberta
If its installed correctly and set right on the clutch correctly, there should be no side loading when the torque its applied. It should be a straight pull on all three steel pieces.
snow-doo
448
306
Atascadero Ca
I bought one similar to this from Goodwin Performance and I have had no problems with it.
Gen 4
