Not sure if the was the best place to post this....
If you measure the diameter of a 9 tooth 2.52 pitch driver (Arctic Cat for example) it is actually 6.94". If you calculate what the diameter is, it comes out to 7.22" Now if you take a 2.52 pitch track and lay it on the floor and then place the driver inside the track and roll the driver inside the track you will see that the teeth of the driver do not stay centered in the lugs as you roll the driver. You can actually see that the diameter is too small and the timing or pitch between the driver and track are not exactly the same.
On Whal brothers website they sell drivers and list the diameters. They are all about an 1/8" undersized versus the calculated diameter. It seems like they are doing this intentionally for some reason. Wouldn't you want the diameter/pitch of the driver to exactly match the track for best performance?
I have heard of racers building up the diameter of the drivers but I don't know if they are doing it to solve this problem or for some other reason.
