BRP Style Ice Scratchers on a Polaris RMK with Pictures
440revNL
181
168
Canada
Hey, so I've seen a lot of people on forums looking at getting better scratchers for their RMKs to replace their stock Poo ones. the BRP style ice scratcher, also made by RSI, is the best IMO. With the dual coils it has less of a chance to break vs the lightweight titanium ones on the market.
1: Removed stock scratchers
2: Using a grinder, file one side of the lower nut. (Right nut in the pictures below. This allows the lower positioned nut to clear the rail profile that sticks out on the back side.
3: Install BRP/RSI style scratchers in stock holes on the rail. No drilling for these two bolts. Circled in red. Tighten.
5: Mounting the scratcher holder can be done in a couple positions using the stock hardware, or you could purchase DURAFLEX™ ICE SCRATCHER HOOK, CLAMP. This allows you to mount a holder without drilling. Or you can drill a hole in a similar location but there won't be much of the scratcher holding on.
I ran the BackwoodsBMP rail brace, so I just drilled a hole to mount the holders closer to the scratcher so it wouldn't pop out as easy. This style flicks more snow/ice up sooner than the stock Poo ones so it helped with cooling.
Cheers
Zad
143
98
Thanks for this. I'm replacing the stock scratchers on my '22 Matryx, intersted to know why you chose the BRP style over duraflex?
Mar 6, 2008
511
346
Northern Sweden
If you use BRP's scratchers remember that the Polaris track is 1" narrower on each side than the BRP tracks. This means that the coil bit protrudes past the track edge 1" more on a Polaris than a Doo.
I've had them on several Doos and Lynxes with the wider track with no problems but I had the Doo scratchers on my last RMK and I did loose one of them before I had even used it, I assume that it got hit by a tree stump or something similar and got "peeled off". After that I kept them in the garage until the season made them necessary.
Chadly
Forum Expert
2,314
4,565
Snohomish, WA
If you use BRP's scratchers remember that the Polaris track is ½" narrower on each side than the BRP tracks. This means that the coil bit protrudes past the track edge ½" more on a Polaris than a Doo.
Let me fix that for you
440revNL
181
168
Canada
Sheetmetalfab
7,924
6,683
The brp scratcher base plate cracks and falls apart.
Leave them in your garage.
C
Nov 29, 2008
771
374
Don't need the holder - end of the scratcher tucks nicely into the rail cutouts
Sent from my motorola edge plus using Tapatalk
idahoskiguy
893
663
93
Boise, ID
Have installed the BRP scratchers on three PROs and they work well. Tried to order a set of the new Poo scratchers and was told they won't be available until April.
Saturday, while crossing a rodeway with icy berms the Khaos rolled backwards and bent the stock scratchers so will convert it also :ROFLMAO:
