Alpha vs twin rail and whether to go back to twin
summ8rmk
Most handsome
12,368
6,039
yakima, wa.
Are shocks interchangeable between alpha and twin rail skids
Rear is, front is not.
I think the rear is valved different?
I swapped rear shocks and it handled different with the same pressures.
Sent from my SM-G998U using Tapatalk
Chewy22
1,996
1,371
Montana
Summ8rmk is correct, the rear are the same length but the valving is completely different and the cap on the bottom end of the shock is slightly different. I started out using the alpha rear and damaged that shock, so replaced it with a twin rail rear. There is a noticeable difference between the two. Overall the sled was more compliant with the correct valving. Like summ8rmk mentioned, changing the air pressure could help; something I never tried. The biggest thing, make sure you position the shock the right way, both vertical and cap direction at both ends. That rear shock can only be installed one specific way on the twin rear rail setup........don't ask me how I know! :ROFLMAO:
sno*jet
2,829
1,299
Kinda surprised you didn't just flip those drivers around on that driveshaft and put a 3.5" pitch track like 300lx or whatever, but the ol power claw aint too bad I guess. Id like to try a 3.5P track on mine sometime, see what all the fuss is about.
Clark42
690
501
Washington
How much for track?
I sent you a message
I am curious about that, seems like 3.5 pitch is where the traction really comes from. Maybe I'll keep these drivers around for down the road. It's just convenient to go with what I know
