B
Mag side piston tweeked a while ago and now have it back together and trying to set the idle. When the engine is cold starts up and idles at about 2200 and then idles down to 1400 when warm which is a little low. I can't seem to find a speed inbetween those two numbers. When making small adjustments, speed jumps from 1400 to 2200 when the speed does change. At 1400, it idles quite smoothly. Are there any adjustments to the carbs that I should look at?
When I tore down the engine for repairs, I noted there was no oil flowing out of the supply lines. After re assembly, I attempted to purge the oil lines but could not get any oil flowing. Took the line off the exit side of the filter and no flow. The oil flowed quite well when I removed the filter. Took the filter apart and there was only some clear gunk clogging the screen. 3 years ago, I had changed this oil filter, drained the oil tank due to the fact that the sled had not run in a while, and topped the tank off with blue Poo oil. Just used up the last of the 4 litres of the Poo oil. Is it normal to have the filter plug off on a machine that does not get a lot of use? Should I make replacing the oil filter part of my annual maintenance on all of my machines?
