The guy i bought the sled from said the engine is from an 03 PROXr(but i am not 100%) my polaris dealer told me the 03 vertical escape and the
03 PROXr got the DET sensor.
it was a while ago i messed whit it so i forgot that i have checked the carbs, tried another fuel pump, tried a 18 degree CDI, tried another ignition coil, checked the temp sensor and it let through the right ohms,
i checked all the wiring,
i know You can't plug a non-DET CDI into a DET CDI harness or vice vrs, but you can change the harness from the stator and put a non DET on a DET engine.
(there is a hole in the head where a DET sensor i suppose to be)
i do not know if the engine ever ran okay, i bought the sled this way, taught it would be an easy fix
it does not free rev beyond 6500. so i do not think it is a clutching matter and it still got the 440 gearing.
i have tried a timing light and it looks like it misses a little bit, but only on one cylinder.
and some times it runs perfect trough the whole register (but only for 10 minutes or so)
it is slp twin pipes on it, i do not know who fitted them, i taught about that to and i think i will try a single and see what happens.
it is not like it doesn't have the power to rev more than 6500 its sounds more like an ignition problem (it misses and sounds real bad)
