2018 Mountain Cat M800 Overheating
J
Oct 20, 2023
9
Idaho
I have a 2018 Artic Cat Mountain Cat M800 duel rail that is having overheating issues and wanted to see what others have done to fix this issue. The sled will overheat on trails and in powder. I've had it overheat in deep powder multiple times. When this happens in the powder, it will take a couple of cool-offs before it stays at normal temp for the remainder of the day. I could run multiple days with no issues and then it pops back up. It's pretty sporadic. It is frustrating when I run with a lot of friends who have Alphas with no flap and their sleds have no issues other than normal overheating.
I have always run with a flap even though I want to remove it.
I run scratches on trails no matter what.
I changed out the thermostat last fall and did see a little improvement. I can't remember if I put in the 2020 model thermostat or the original 2018 OEM thermostat. I think it is the newer one. ( I know the new opens at a lower temp)
Put new coolant.
I have checked for air bubbles.
I was thinking of just removing the thermostat completely. I know this would take the sled longer to heat up. ( It already takes longer than many sleds to warm up)
Any thoughts on this would be great.
D
Apr 20, 2017
3
41
I chased a very similar issue with a 2020 alpha the entire first year. What I found was the skid plate wasn’t fastened good the entire way around the belly where the cooler was and certain conditions it would catch enough snow and ice over the cooler completely and for that would cause it to overheat a ton. Rode it for 3 seasons after with zero issues.
A
akdanno
Feb 22, 2022
40
29
18
Alaska
I had a similar problem on my 23 mountain cat. It was water inside the wiring harness, specifically at the plug for the temp sensor. I pulled all the plugs on the machine and packed them with dielectric grease, problem instantly solved
J
Oct 20, 2023
9
Idaho
Ill look into this. thanks for the reply.
J
Oct 20, 2023
9
Idaho
Ill look into this and see if it is the fix I need. Thanks for your reply.
boondocker97
4,077
2,795
Billings MT
Had the same thing happen on my 2014 big bore after doing a top end. Changed thermostat and burped coolant several times. Plumbed in a fuel pressure regulator to the line with a gauge up by the handlebar and found the fuel pressure would drop intermittently. Tested voltage to the pump and it was low. Ohmed the stator and it tested bad. Was basically running the sled a little lean. Especially in deep snow at WOT. So if you don't find anything else check your fuel supply.
A
akdanno
Feb 22, 2022
40
29
18
Alaska
I pulled the flap off mine on day one. If you have coolant and no mechanical issues, you should never overheat in deep snow
J
Jul 21, 2022
125
20
18
USA
I have a 2018 Artic Cat Mountain Cat M800 duel rail that is having overheating issues and wanted to see what others have done to fix this issue. The sled will overheat on trails and in powder. I've had it overheat in deep powder multiple times. When 192.168.100.1 192.168.1.1 this happens in the powder, it will take a couple of cool-offs before it stays at normal temp for the remainder of the day. I could run multiple days with no issues and then it pops back up. It's pretty sporadic. It is frustrating when I run with a lot of friends who have Alphas with no flap and their sleds have no issues other than normal overheating.
Put new coolant.
what coolant do you actually use ?
Old & slow
728
393
Alberta
Put new coolant.
First off AC has a excellent cooling system and you should not be having these problems. I would not recommend removing the T stat and running it. There is a possibility of a cold seizure when doing this and pistons and cylinders are expensive. Did you elevate the front of your sled a foot or so when adding coolant this will help with air removal. Scratchers on the trail are a must with the 3 inch tracks. Checking electrical connections are a good thing to do just for routine maintenance. Also inspect the wiring harness for rub through or damage. The coolant temp sender can also be checked for resistance with a multi meter. Go to Country Cat and they have service manuals available on line you will find a chart with the specs. If you are still having issues I would first confirm that the engine is actually hot a temp gun works good for troubleshooting. If it is still overheating I would go back to the t stat remove it and test it. I don't think its the water pump as most mechanical issues are either it works or it doesn't. Good luck and keep us updated!
J
Oct 20, 2023
9
Idaho
Ill start going through all of this. Thanks for the suggestions.
Ol* Geezer
173
86
My sled and 2 others in our group have had this problem. I replaced the heat exchanger with the longer one from a Cross Country sled and completely solved all my heating problems.
B
Nov 11, 2010
729
415
Salmon Arm BC
My 19 started running hot under normal conditions on the trail but stayed cool in powder so I changed the t-stat and it runs normal temps now.
IIRC there was an issue with some of the 18/19s and the impeller slipping on the water pump shaft at higher RPM. That could be your issue.
A
Mar 21, 2023
4
1
3
WA
I was having intermittent overheating issues on my 2019 m8000. Sometimes sled was fine, other times it would overheat constantly. I changed thermostat to the new part number and installed a new SP1 radiator cap( like 1/2 price of cat). Coolant filled to just below filler neck. No issues since.
J
Oct 20, 2023
9
Idaho
Thanks for the suggestion! I will look into the radiator cap.
J
Oct 20, 2023
9
Idaho
Thanks for the suggestion. I will check on the impeller.
R
Jan 10, 2024
1
ASV
