2016 M8000 Oil Injection Parts
M
MRog40
New member
Jan 23, 2022
24
2
3
Fargo, ND
Hey guys, I bought an M8000 that was converted to premix. I'd like to go back to oil injection, can anyone summarize how that system works?
Is there an oil pump and separate injector, or is the oil pump itself variable and controlled by the ECM?
Where is the oil injected?
I know I'll need an oil tank and oil pump, I'm just not sure what else I'll need.
boondocker97
4,077
2,795
Billings MT
The oil pump drives off of the water pump shaft on the front side of the crankcase. There is an arm that goes from the throttle bodies down to the pump to control the flow. It's all mechanical on the Suzuki motors. Oil injects into the bottom of the reed cage boots.
Probably the cheapest new pump you will find: http://www.bd-xtreme.com/index.php?id_product=55&controller=product
Here's a new oil tank too if you don't have the dropped driveshaft on a 2017 mountain cat or if someone hasn't converted it: http://www.bd-xtreme.com/index.php?id_product=473&controller=product
Or someone might have these parts sitting around in their garage they just want out of their way after doing their own deletes and belt drives.
This is a clean way to do it too and leaves you with more space under the hood: http://www.bd-xtreme.com/index.php?id_product=442&controller=product
M
MRog40
New member
Jan 23, 2022
24
2
3
Fargo, ND
Thank you so much for the info and the links. You're making my life much easier.
The sled has belt drive and drop and roll kit so I can't go with the crank case tank. I suppose I could go with any old plastic tank like the ones M series sleds had
J
Jul 21, 2022
125
20
18
USA
Hey guys, I bought an M8000 that was converted to premix. I'd like to go back to oil injection, can 192.168.100.1 192.168.1.1 anyone summarize how that system works?
Do you have the users manual ?
boondocker97
4,077
2,795
Billings MT
Most of the belt drive manufacturers have 2 quart plastic tanks that bolt to the side of their kits for sleds with oil injection. I would just get ahold of whichever company made yours and get the tank setup from them.
