T
Yesterday i went out by myself and enjoyed some of the seemingly bottomless powder we've got right now.
I had a problem though. once i got up the "trail" (one track through the new snow) and to the area where i started playing and boondocking, i would start to lose power after a few minutes of playing.
The first time it happened scared me because it was at the top of a particularly long full-throttle pull. I was just starting to think to myself, "man, this is a long pull, gotta be building some serious heat." Of course as soon as i thought that the engine started to lose power and i figured i was starting to seize.
Well i don't think it seized, it pulls over smoothly and after sitting for a while and cooling down, it ran just fine. So i shrugged and went back to riding. But every several minutes the same thing would happen. Lose power, sit, wait, go fine again.
So now i wonder if my carbs were icing up and sitting allowed them to thaw out again. THere was a little bit of snow in the airbox.
Here's what i'm running:
03 800RMK stock engine
SLP single pipe
SLP intake
I had some problems last time out that i thought may have been water in the fuel, so i added some ISO Heat brand fuel additive that is supposed to absorb water (isopropyl alcohol). Then when i went to fuel up, everyplace was closed except the Arco station, which i typically avoid due to rumors of sub-standard fuel quality. Since I had to get Arco gas, i also dumped in a little octane booster. I put in about 5 gallons of the Arco gas which was labeled as being up to 10% ethanol. And i had maybe 1/4 tank of 92 octane ethanol-free fuel from the last ride.
So i had quite a cocktail in the gas tank.
Other than carb icing, my dad suggested possiblities of clogged intake or exhaust. My sled does not have the little deflector on the bellypan in front of the exhaust, i'll have to make one and rivet it on. I also have only the stock intake vent. The foam mesh by the steering column was usually caked with snow. I was carrying a foot thick layer of snow on the hood most of the time.
Snow was awesome, and when it was going, the sled was going good! What was wrong?
SLP single pipe
SLP intake
