I haven't been able to get it to start for a while, so I went with the basics--yes, I have spark, I pulled the pick-up line and it's in good shape, replaced the fuel filter.
So I cleaned the carbs being very careful not to change settings on the throttle cable or the idle screw. When I removed the bowl from the Magneto carb the main jet fell right out. It had vibrated loose and spun off. I thought for sure this was the problem, but when I reinstalled the carbs the sled still wouldn't start.
One night after pulling a few times, I turned off the fuel line. The next morning I turned the fuel back on and it started in 3 pulls. It was running great and had lots of power. The crankcase must have been full of fuel because it started dumping fuel out of the exhaust. Once that was out of the system it ran fine. For the next few days I could start it within just a couple of pulls. Then from one day to the next and without warning it was dead--couldn't start it to save my life.
So I dragged it into the shop and immediately pulled the float bowls off the carburetors again. Lo and behold, the main jet had vibrated loose again and was in the bowl. This time I put a little bit of teflon tape on the threads and reinstalled.
Since the carbs were out and the air box was off, I decided to check the synchronization of the carbs. I downloaded the service manual, watched a YouTube video, and followed the procedure precisely. The carbs were way out of adjustment. After reinstalling the carbs the machine started within 3 pulls again. It dumped a bunch of fuel out of the exhaust again, but the engine had lots of power. For the next couple of days it would start within 3 pulls consistently. I thought I had finally figured it out.
Last night I brought it home and allowed the kids to ride it around the yard for about 45 minutes. It was running great and they were having a ball. They stopped in the front yard to change drivers while the machine idled. Out of nowhere it died as though someone had hit the kill switch.
The kill switch was up. The key was on. Even the engine was warm and had been running consistently for 45 minutes, the sled refused to start. It was a little low on fuel, not empty but low, so I put a few gallons in. Nothing. I checked the spark--plenty of spark. Even when I pull the rope the headlight comes on. But it doesn't want to start. It doesn't cough or sputter like it even might start.
I was convinced that the main jet had worked itself loose again. I pulled both carbs out and the main jets are secure.
So it's either related to an electrical problem or a fuel problem.
Electrical: How many built-in safeties does this thing have for an electronic shutoff? It has a key, has a red button on the handlebars... anything else that would cause the machine to refuse to start? If the key were off or the red button were down, would the headlight still get power when trying to pull start?
Fuel: Where it has fresh fuel, a brand new filter, newly cleaned and synchronized carbs, and I removed and inspected the pick-up line and screen inside the fuel tank, the only other thing I can think of would be the fuel pump. But would a fuel pump run great or not at all intermittently if it's failing or would it just run more and more weakly over time?
I appreciate any advice you guys can give me. I'm at my wit's end here.
