H
take preload out of rear spring
reduce rear damping
I adjust center shock/front track shock relatively opposite accordingly (like a seesaw)
Add front ski shock preload if it’s not much (guessing based on your weight/size)
Move feet farther back
Ride brake a little before seeking lift then telease like a clutch
Unweight and maybe pull back on bars a little (make sure risers are parallel to steering post)
Use more throttle
Beyond that, you’re looking at considering Khaos type rails, altered geometry front spindles
reduce rear damping
Use more throttle
