A
Hey I got my new cylinders and spacer plate back from racin station. I got it put together with new pistons,wrist pins and bearings, new base gaskets. Now when I go to give it full throttle it is like it drops a cylinder and runs about 7200 RPM. Now I checked the fuel pressure it was right at 43. I checked spark, and it doesnt lose spark.I checked the compression and it was right at 150 PSI in both cylinders. I have Supreme Tool power valves so I swapped them around to see if I had a bad one and I wasn't that. I changed throttle bodies thinking I had an injector problem. On my EGT's my PTO cylinder reads fine till it reaches about 7800 which is when it starts dropping that cylinder and the temp starts to drop fast. It will drop to 200 degrees if you hold it wide open. I checked the tail light wiring harness, all looked good. I disconnected my boondocker box and the same thing happens. I checked the reeds and they look great. I pulled all the weights out of my clutch and it made no difference. I checked the primary spring and it was ok. I dont know what to try next. any new ideas would be great, I'm sure I'm missing something simple I just don't know what.
Alex
Alex
