‘22 Boost Low End Power Sucks
P
Feb 4, 2008
128
34
Cle Elum, WA
My dad picked up a low mile (350ish) 22 boost 165 and it seems to really load up on the bottom end. Has anyone experienced this and what was changed to fix it. My 23 turbo r blows it away on the bottom end. I can see it leaving an oil mark in the snow every time you get on it. I don’t think it is clutching.
Chadly
Forum Expert
2,314
4,565
Snohomish, WA
Make sure it has the brake/map flash. Without that, the sleds aren't even comparable.
Chadly
Forum Expert
2,314
4,565
Snohomish, WA
Is there a way to know what map it has? And is that the map that made it so you can’t run the brake and throttle at the same time?
That's about the only way to tell. Go ride with the brake on. If it goes into limp mode then you have the newer map. I'm not sure but there could even be a newer one this year for all the Boost that may be better yet.
JH@CM
493
771
93
and/or login to the polaris site and see which recalls have been done.
The stop ride brake recall flash last year also updated boost mapping.
And of course, a dealer can solve this once and for all.
Sheetmetalfab
7,917
6,678
Is it in ethanol mode?
Wheel House Motorsports
29,933
5,968
SW MT
Easy test at home. Put it on trackstand and run the track while gently dragging the brake. I'd it starts flashing in a few seconds new map.
Also double check fuel mode. It will change back to the ethanol map randomly for some reason so verify that. And I'd bet it doesn't have the brake recall mapping. It's a huge change in bottom end.
Also clutching. The stock 22 clutching is a little aggressive on the bottom and makes response pretty sucky
Chadly
Forum Expert
2,314
4,565
Snohomish, WA
Comparing the bottom end of a turbo R to a boost is unfair even when everything is working perfectly on the boost. The boost bottom end is horrible compared to the Turbo R doo.
Ha I didn't even catch this... We are all wasting our time here. The Polaris Boost is not even in the same league as the Ski Doo Boost. I thought you were comparing a 22 Boost to a 23 Boost. Polaris Engineers are working about 10 years behind the French Canadians.
madmax
3,146
Salt lake city
Make sure it has the new updated tune, it makes a huge difference on the 22’. My 22’ seemed like a NA 850 against my G5 until it got the new tune.
P
Feb 4, 2008
128
34
Cle Elum, WA
Today I took off the belt and it does have the brake map. It was reverted back into ethanol mode again.
Well that’s a bummer if it doesn’t even come close to the turbo R. I just didn’t expect it to load up that much in the bottom.
Will clutching help it? I just see it making it hard for him to get on top of the snow.
Sheetmetalfab
7,917
6,678
It likely was in ethanol mode all day.
I check mine 4-5 times a day.
