Wanna see some flaky rings?
Thanks to all to input from this forum, I was able to make an informed purchase of my 04 800HO. After looking inside the cylinders before buying it and buying new rings right away, i finally am changing them before this season. Look like the talk about the flaking rings is pretty accurate in my case. Sled has about 1200 miles. Hopefully...an ounce of prevention.
Check out the pics. Top one in each is new BRP part.
Duh....which way does ring the dot go?
I forgot to note the postion of the dot on the rings. They are semi-trap and have to go in one way....I just can't remembger which way. I have the complete shop manual, but they don't address it either. NAy quick help would be appreciated.
Thanks guys. Did some homework and found that 'dot up' is standard and 'wide' edge up.....makes sense for compression. YA...probably should go with new slugs too.
