Sincere questions..
No decrease compared to running what other fuel?
In what kind of sled/motor/mods/compression ratio?
Are your "before" and "after" throttle response impressions made on the same day?
Thanks for that link to
http://www.airnav.com/fuel/local.html... Very easy to use!! $4.45 Self Serve at my local airport.
I really want to "believe" in AV gas... especially since it seems to be not only a higher Octane fuel, but a higher Quality fuel compared to today's "pump" fuels.
With the Radically different Evap temps of AvGas (90% evap @ 275°F) compared to VP110 (90% evap @ 211°F)...Throttle response and piston cooling would be different to
SOME degree.
Also, 100LL has a lower heat of combustion at around 18,715 BTU/lb (about the same as E-10 gas)... compared to VP100 or Pump91 at around 18,800 BTU/lb...
100LL and Ethanol added pump 91 have less engergy per unit burned... in comparison, VP C-12 has about 20,500 BTU's/lb.
I need to do more digging to find out about the stability of AV Gas as well... meaning storage longevity.
