Swapping BD Side Kick Turbo kit from one sled to another?
sierra sleder
94
23
8
Montana
Looking for advice from others who have removed a Boondocker sidekick turbo off one sled and installed it on their new sled. What are some parts that the older sled is going to need to be replaced with etc. So I have a 2019 Polaris Axys with 2019 boondocker sidekick turbo kit and I’m looking at removing this kit and installing it in my new snow check 2021 kahos 165. Talked to Boondocker and they said it will install on new sled. I was running the original (version 1) mapping/tune from boondocker which was to run 50/50 pump gas and av gas because it ran so good and never had problems so I just stayed with it. Stock head, No cut head (Colorado or Idaho head). I also had the tunnel dump deep snow exhaust on the 19 Axys so I already got the Block off/hole cover plate from boondocker to cover up the cut hole. I suspect I’m going to need to do some clutching kits/work for both sleds and probably buy a exhaust can for the old sled. What else should I consider when having dealer do the turbo swap on the sleds?
brianschra
New member
8
1
3
My question is regarding the 19 850. How did it run overall? any issues regarding the top or bottom end? and was it 50/50 100LL?
