G
This is a 2006 Arctic Cat M 800. It is the best sled you will ever own. It was a Factory hill climb sled that was hardly used. It did take 3rd place at Jackson Hole Hill climbs in the 1000 improved class, and did very well all year. I have owned it since 2006 and have never had 1 problem with the sled (did replace the spider in clutch). This snowmobile has everything you need on it already.
$6000
It has the Speedwerx 800 motor,
Twin race pipes,
Welded and balanced crank,
Ported and polished,
Speedwerx heads,
V-force reeds,
Sno-pro air box,
Snow pro front air bra,
Side air vents,
Shock tower vents,
2 wheel kit on rear,
Ecu programmed from factory for engine (no box needed),
Wider front A- arms and shocks,
2009 HCR skis,
Handle bar riser,
Boss seat (the good one, not the real soft one)
Snow eliminators,
Holtz front arm relocate,
Oil eliminator,
Newer 153 camoplast track, "ported"
BD rear bumper kit, and led light
New 10” 1/4 secondary clutch,
bmp tortional sec. spring,
Cutlers adjustable weights in prim. Clutch,
The clutch is exactly on,
No cracks in hood,
Probably more that I have missed,
This is the best sled I have ever owned by far. I wont say that there is not a snowmobile that will beat it, But unless it is a turbo there is not much than can climb like it. I hate to get rid of it ,but I bought a new one just like it. I hope it will be as good as this one was to me.
$6000
Twin race pipes,
Speedwerx heads,
V-force reeds,
Sno-pro air box,
Side air vents,
Shock tower vents,
2009 HCR skis,
Handle bar riser,
Snow eliminators,
Oil eliminator,
No cracks in hood,
