ZX skid setup
M
Motley Doo
Over the summer, I put a 162 under my 01' Summit X hmk 800 144. I did a skid set-back with a big wheel kit and the offset axle reversed so it angles back to take up some extra track. When I did it, everyone told me to drop the center front pivot on the skid down 3/4" to get some weight transfer back, so I did. After a pretty good dump of snow, I was out messing around in the field and noticed that the sled doesn't pop up out of the snow or plane out like it used to. It just trenches and won't pick up any speed. If you transfer from the soft to the hardpack, it will rip your arms off! I know my ski's suck but I was hoping that it was just the skid geometry was off. Also, as of right now, the sled is super tippy! If you slide your butt to one side or another, it about falls over on its side, so do I need to move the skid pivots so the skid sets flat when you lift the rear end? I was going to mess with the limiter strap before drilling holes, but wouldn't that preload the center shock and make it rock hard? Also, how do you run your spring preloads for the soft stuff? Thanks for all the help!
How far did you set back?? Redeye racing's set back was 3.5" back 1" down. But also the rear siccor was moved 2.5" forward on the rails. Mine was a 151 to 159 plus big wheel kit. I think I still have the instructions if they would help.
It is a ski-doo skid. I'll measure it tomarrow, but we also changed driver size so we hung the sled at about ride height and just set the skid inside the track and pulled it back to near tension, put the back pivot bolt in(scissor is in stock rail location) and dropped the front accordingly. Hey bigcat, was that a 1" drop for both pivots? Thanks for all the help guys.
For the best set up the original plain needs to be maintained. The kit I got did include a rear bracket extension to lower and move back the rear mounting point.
Well, I got sick of the narrow running boards and just built a new tunnel and built the brackets into it, and I built it with the intent of moving the skid around a bit, so I have plenty of space. I might try dropping the rear of the skid 3/4" to flatten the skid out to where it was. Also, how do you run your springs, soft center and stiff back or soft all around? Thanks for the help!
Ok, thats how I had mine set-up, minus the Fox shock.I think I'm going to move the rear of the skid down to parallel with the ground, I'll look at it a little harder tonight. Thanks.
