just went from a 144-151 and was looking at dropping the rear end down 2 inches or so.
just wondering how far people are moving the skid location backwards for good results. i was thinking 2 inches back and 2 inches down in the rear.
so by moving it back by 2 and down 2 what does that improve???
sled is an 01, skid seems about 3 inches forward from my 02 machine
2 down in the back and move complete skid back 2-3" notin the front would that not give a better angle of attack.
winter brew With the '01, match the measurements on the '02 and you should be able to fit the 151 without any rail extensions. This will make the approach ALOT better....just like the '02.
It is Critical that you keep the spacing of the mounting points as they are or it will cause suspension to bind up. You can drop and slide back as much as you want however keep in mind that you will be increasing your approch angle. However 2 inches in the rear is really a min amount.
A Quick reply to the referance to Kinetic's. Owners was Rick he sold set-ups to a number of people and even got Team industries to use his set-up which was a disaster as Rick is a trail rider and doesn't climb really at all. Took me two seasons to get mine set-up right. As testing wasn't being to corectly for team industries. Helix's and springs and weights were all way off.
