ZR 900 Turbo??
Quick question: Is it possible to make decent power out of ZR 900 Turbo on pump gas at low elevation? I generally never ride above 1000 feet.
Thanks
yes if you retard the timing 2degrees
you should get 200-220 on 8lbs boost depending on turbo used megga safe at 6lbs boost you loose a bit of bottom end but the mid and top rock.
