Its true. Air cooling on a snow machine sucks. Keeping one radiator with a cap for filling and pressure relief is good. then a heat exhanger in the tunnel will give you more cooling than you will ever need. It is so nice to ride in any
conditions and not worry about engine temps.
Dirtrebel, Sorry, back to gearing...So if I get an 18, do you think I'll have problems with chain length? How did you figure that you couldn't run 17/17 due to chain length? I am thinking I would like larger gears, like 17/18 or 19/20 so that I don't have to remove the knockouts. Waddaya think?
Impressive thanks a lot.... something else to add to the list....heat exchanger is the bomb! temps ran 132-137 (f) almost all day, super consistent! spiked (if u could call it that) up to 144 once at the top of a looong pull. before on the same pull would have been 200 easy by the top. Ran great, a little fat midrange and a touch lean on the main jet. carb heat collar worked great! The hardest part was getting it filled with coolant, had to bleed it alot and prefill the exchanger and lines but after parking on a hill a few times and a few laps around the yard this morning it got primed and bled. I don't think you need the one radiator but it makes filling and plumbing easy but the exchanger itself is plenty of cooling, only half of it gets warm. Awesome, my 450 is next!
any updates??? should I sell my 450???
