H
High Velocity
LoudHandle, the clutch was manufactured on July 25, 2011.
Sent from my iPad when I should be sledding.
The clutch on my 2011 broke Friday with 2000 miles, rode it the remainder of the day thinking it was a bushing hanging up, got lucky and made it home fine.
Pulled the primary bolt out and it fell in two half's. Called the shop they said to install the clutch pulling tool with the broken half of shaft ( shaft removed from the spider ) and weld it. So I did took about 45 minutes to remove it. As for the heat on the crank bearing, it's a good 4 to 5 inches away from the crank seals, I could hold my hand on the crank no problem right after it was removed. The shop told me they would charge 1 hour labor to pull it so a little less damage to the wallet.
One last comment, before you weld the two half's together make sure you leave about a 1/16th gap or your welds will break from stress when you start pulling on it, you will also be able to see where you need to weld. it is very important to build a protective area around the area your welding, so good heavy damp cotton shirts can suffice to keep hot slag and prevent dingle berry's from damaging hose's, plastics or wires or getting ding berry's on your secondary.
2012, approx. 2200 miles. Luckily happened in the dealers shop when they were pulling it off to install new motor mounts. warranty covered.
Motor mounts can be switched without having to pull primary
Why are they braking ? Made in Mexico ?
Luckily they pulled the primary instead.
Without removing plastics, I don't see how you'd get to the one behind the primary..
