H
High Velocity
The primary clutch on my '12 Pro broke in half today. What have others found is the best way to remove it. Carefully using a zip disc to cut the remainder off the crank, or weld it back together and pull it off ? Does the welding put too much heat into the crank seal ? I am set up and able to use either method, just curious as to what route is easiest. All input is appreciated. Thanks !!
Sent from my iPad when I should be sledding.
