Y
I parted out a 2003 yamaha viper and I still have a lot of stuff left over. I am moving and need this stuff GONE. No reasonable offers refused. Discount for anyone who wants to buy it all as one big lot.
Pics of most items are located here
Stock pipe and can-low miles
exhaust deflector
Jackshaft
Steering post
Carbs
trailing arm mounts
fuel pump
oil pump
motor mounts
Stock Reeds
front heat exchanger
coolant bottle
coolant hoses
thermostat
headlight pod
rad rod-belly pan bracket
spindles and arms
brake caliper and rotor and e brake
brake controls
choke cable
clutch puller
under hood steering assy.
rail extensions 141 to 151
water pump cover
air box
oil bottle
recoil w/good rope
stator and flywheel
powervalves and servo
front bumper
coil pack
wiring harness
CDI and sensors
Ignition and key
exhaust deflector
Jackshaft
Steering post
Carbs
trailing arm mounts
fuel pump
oil pump
motor mounts
Stock Reeds
coolant bottle
coolant hoses
thermostat
headlight pod
spindles and arms
brake controls
choke cable
clutch puller
water pump cover
air box
oil bottle
recoil w/good rope
stator and flywheel
front bumper
coil pack
wiring harness
CDI and sensors
Ignition and key
