Yamaha Ovation 92' LE won't start
Need some ideas. I have a 92' Yamaha Ovation and it won't fire. I changed the plugs and they will only spark once when i let go of the ignition. Gas is getting into the cylinder but there is lack of spark. I ordered a new ignition coil hoping that will solve the problem. Haven't gotten it yet. Any other ideas on what may be wrong?
not that its relevant, but i had a 76 rupp nitro, that was running one minute and the next it had no spark, it was irritating and i went through so much crap, and it ended up being the stator, i know it sound scary but its very simple to replace, maybe replace the cdi box? had a phazer do that once, so maybe try that stuff, if you get the ohm readings for your machine, you can check the ohms from the stator without ever pulling the thing out, just an idea..
It will most likely be the source or trigger coil. I think they are available separately and you can solder them in. You will need to find the wire colors and resistance values for them and test away. Not to often the CDI or ignition coils go. Good luck. Shad
