Y Pipe bolts - torque?
G
gman086
What's the torque supposed to be on the Y pipe bolts? And have they been problematic with loosening like BRP's stuff or not an issue with Poo?
Thanks,
G MAN
Thanks. The Liberty 800 was 16 ft/lbs as were many others so I just went with that and it seemed about right. None were loose and they use toothed washers so I'm guessing never a problem on Poos with loosening.
Cheers,
G
I was pulling my exhaust valves the other day and checked the y-pipe bolts. They were all snug as could be (I don't know the torque spec). but I did notice that the PTO side had some oil leaking out. I heard others say the same thing. I just checked the bolts and left it alone.
The Exh. Vavle dump hose is on the PTO side.. Kinda towards the bottom..
i rerouted the hose more to the exh. side.. i was seeing oil build up on the block and on the clutches..
my .02 reroute the hose.. or put a elbow on the end of the hose
