Got a customer that wants to convert his XTX skid to a 174- 2.5" wants a Timbersled skid rails and all. What drivers will work or will it work? trying to talk him down to 162 any thoughts?
From what i have heard with the 2.5 inch lug you can run the stock, or even better the avid drivers. It is the 3inch lug track that gives clearence issues in the front. If ur changing drivers anyway then camoplast recommends going to a 2.86 pitch track instead of a stock 3inch pitch. the 2.86 is molded differently and ends up being a way better design. Tracks usa said they have not seen a 2.86 camo extreme fail, but lots of the 3's tear lugs off. Changing drivers is way cheaper then having to buy two tracks cause lugs are flying off. Talk to tracks usa for more info, they are a sponsor on here.
Is there any difference in the centre to centre of the XTX to the MTX? If you use short centres with a long track, then the leverage against the rear shock is way to much for it to handle. With longer c to c the rear shock does not have to work nearly as hard.Got a customer that wants to convert his XTX skid to a 174- 2.5" wants a Timbersled skid rails and all. What drivers will work or will it work? trying to talk him down to 162 any thoughts?
The reason they havent seen any 2.86 fall apart is because all the sleds running them are only making 120 hp, probably less at altitude.![]()
