XRS Panels
E
Elkwagn
Any thoughts on cleaner to use on yellow XRS side panels, or are they always dirty yellow? Just picked up an 07 XRS and the side panels are really dirty, not sure what to use?
They will not clean unless kept clean since new, Oil will absorb into the plastic. I when all black.
Yellow is tuff to clean for sure.........WD-40 works well, Magic Eraser works pretty good too.
simple green works great for that kinda stuff. FYI, carburetor cleaner works awesome on the yellow panels, takes off any oil and works real good to get rid of the marks from the pull start slapping the panels but its really strong stuff. id give it a try in a small area and see how you like it first. i only use it for real tough stuff more as a last resort.
So far the WD-40 has worked the best, brake cleaner works good too, but seems to turn the plastic white in areas
Side panel
FYI, once you get them clean, hit them ith a heavy coat of Turtle Wax "ICE" paste wax. I coat mine once a year and when they get dirty a little warm soapy water takes the grime right off, very easy clean up.
