2009 XR1200 Renegade X
specs-
146/16/2.25
24/49 grear
106 chain
stock/stock motor exhaust
stock ramps
160/350 spring
16.4 gram
click 3-5??
SW variable at 46/43
stock spring wound a couple lbs stiffer than stock
stock 48" front with sway bar
6.9 pilots
6" riser
shooting for 8200-8300
after a couple days..changes for next ride
8" riser
narrower stance (machine spindles, use summit spacers)
remove sway bar
130/350 spring (awesome low end, 160 spring likes to trench if not carefull)
SW with straight angles..shoot for 42/43 degrees
wind up spring 1 more hole
LW can and battery (saves 20 lbs+)
run 7800-7900 rpm
click 4-5
sled ran well..works well even with me on board (6'7" at 300+ riding weight) worked even better with Ralphy at the helm...in impromptu hill drags (2'+ powder) vs many a sled it held its own..beating most, running a close second vs the rest (name the sled, it ran it)...on the lake it faired even better...Today in 3-4 FEET of fresh Cooke blizzard powder it did verything well..I stuck it few times...(used to a 162/16/2.5 and a 200 hp triple-LOL)...the 160 spring caused 1/2 the sticks...I just weigh too much for this kinda snow...I wasnt the only sled getting stuck..saw many a MOUNTAIN sled w/s deep stuck...BJ
specs-
146/16/2.25
24/49 grear
106 chain
stock ramps
160/350 spring
16.4 gram
click 3-5??
6.9 pilots
6" riser
8" riser
remove sway bar
run 7800-7900 rpm
click 4-5
