Was wondering if anyone has bought crankshaft off that guy on ebay....if so did you get it che ked for tolerance or just bolt it up?....I need a new crank for 08 summit x....it only went 2800 mi. Thankx ahead of time
I'm pretty sure they are not new rods or new rod bearings. Call BJ for a crank.
Cranks are weak until they are bolted into the case....they can change even in shipping. Also, the condition of the case will also somewhat dictate the runout after it's assembled. No sense in putting a "perfect" crank into a junk case so having someone like John check them out and do the work might be worth the $$.
