why don't people talk much about making changes themselves with XPs? Everyone just says "buy so-and-so's kit." well excuse me, but i ain't spending $300+ on a kit either unless i know damn well what's in it. Don't get me wrong, i think the guys out there putting kits together are sharp guys and some are even my friends - but i want to know what i'm spending money on.
There's a lot more discussion on the other forums about what changes people are making with their clutching with off the shelf parts. But in the doo forum everyone buys kits.
What gives? I know Doo owners are as smart as the other sled brand guys - so why not discuss what works!?
The only person i've seen post up ideas for changes is Turbo Al.
Mines an 08, 154 X with 20 tooth top gear.
What do you want, I will tell you what I have in my clutch but who says you will want it for your style of riding.
I have 414 ramp for start, this only changes the low to mid rpm v.s. track speed. It might slow me a bit off the line but helps take that buzzy low speed feel out of the xp.
Secondly I have been using a blue/purple primary spring. This was a great improvement over the stock purple/purple as again the softer start lowered the engagement and lowered the rpm on the trail.
Now I just installed a blue/blue spring to enable me to run in clicker 3 rather than 2.
For pin weight, I have the stock 12mm set screw, + 10mm + 8mm
This may be adjusted by 2mm depending on results of changing spring.
I also have a 13:1 compression head so it might pull a bit more weight than a stock engine.
377 belt is a must.
Secondary, I tried (and have 2 for sale) EPI yellow spring but went back to stock as the yellow spring just made the engine rev higher. So factory settings for secondary has been best for me.
My sled pulls hardest and has highest track speed if I clutch it to pull 8000 rpm max. I gained 5 km/hr by running at 8000 rather than clutching to run at 8200. This is important and you should take note of the best rpm for your machine.
Start with a clutch puller, a metric setscrew kit from the hardware store (6mm diameter size) and a 377 belt. Be sure the clutches are aligned or even with all above the belts will not last if you don't have them aligned.
The other changes I made are not as necessary but are more to adjust the feel of the sled to my liking.
