XLT Won't start with clutch on
R
rodw7c
I searched couldn't find anything hope some one can help 1996 XLT 600 starts and runs good with no clutch soon as I put the clutch on it wont even start is this a bad clutch or is it the motor I tried two clutch's on was bad for sure. I thought the other one was good but maybe not.
Thanks, Rod
try a compression test maby? might not have enough to pull any load? could be time for a new top end
Are you putting the belt on too? Or just bolting the clutch on and leaving the belt off?
sled_guy
mine had the same problem couldent spin it fast enough with the clutch and belt on
a new set of rings fixed it for the season then it got a top end job in the spring.
