I have one on a 2019 twin rail,rode first season with stock steering,switched to wyoboy/kmod steering arm last season,it adds alot more steering to much in my opinion the skis will turn more than handlebar,so i milled bolt hole toward steering arm center 4mm(+11mm vs +15mm)and welded washer on one side and locknut on other side,
with this mod to kmod arm its turns 1-1 skis and handlebars like a pro rmk,
made new steering rods in 15mm solid 7075 aluminium adds clearence and strenght,
had clearence issue with lower a-arm so added extra washers between right spindle and ball joint.
You should offer 1 arm +15mm for 12-15 spindle and 1 +11mm for 2016+ spindle.The alpha needs it more than the mc to recover from wash out since it can panel out easier.
Not sure some have clearance issues and some don't.
But can still make the sled work without it.
In stock form its on the edge of just enough steering.
But I still prefer it, although like previously said it's almost too much. It needs to be turned down a touch.
Hopefully this year I'll get time to completely redo the steering to a direct post and ditch all the links.
