I've got a simple question. Is the belt just sunk down in the secondary? You do know that you have to spin the track to allow the belt to work it's way up in the sheaves so the clutch can close?
no just extra shims, followed the manual to a t tho
800 or 1100. 800 should have a large washer
Haha what do I win since I was right???
Sent from my super duper sweet iPhone using Tapatalk when I should be doing something productive!
Don't know, you should check to see what they give helpers at the special Olympics.
I am still baffled by the lack of, ......... never mind. Just try to think about it next time instead of running to help.
When you had the secondary off the shaft, did you spread the sheaves so the belt could drop down before sliding the clutch back onto the shaft?
no. how do you do this?
this is all new to me. last snowmobile I had was when I was 10, 26 years ago.
thanks for the help
Here is a detailed video I found on youtube for some of you guys
https://www.youtube.com/watch?v=aBelSjuS-Zk
make sure when you tighten the bolt the helix is lined up, if not it can break the plastic slides inside so be careful.
