I know I know..looking for a deal. Hey just so you know each model is independant to the chassis so if your sled is an XP (which it should be in the years that you reference) then you'll need to get P#0110. There can be confusion between Rev from 03.5 and up but there are actually 3 designs and only one will fit your XP.
Now to further complicate matters I just updated the XP design and it is flat excellent! Good enough that I'd certainly think hard about just buying new and getting the updated version. Better Fit..bigger evacuation holes..and now traction on the front section...and updated scallops for support with a much cleaner appearance. Check out the photo...
BE SURE TO GET COATED BOARDS..THEY ARE WORTH IT IN ALL ASPECTS!
Thanks Rob,
Last year you hooked me up with a set for my 03 ZX.
The performance of these boards was awesome compared to stock, well from what I could tell based on the amount of riding I got.
I put them on right before taking an avy class.
You know how it is you spend your entire bluebird freshie day, retreiving buried beacons. After class is over you have 45 minutes to ride. I was so amped, I ended up taking my sled straight into a ditch and bent the bulkhead. Had to scrap the sled (pulled the f-bombs first of course), and bought a salvaged 07 rev summit with minimal damage.
BTW..You don't place any crazy Gypsy VooDoo curses on your products do you?
Actually it sounds like you qualify for the factory crash replacement program. Check out our website and call it in. WE ARE THE ONLY ONES THAT OFFER THIS PROGRAM AND JUST ANOTHER REASON SNOWMOBILE BETTER BOARDS ARE THE ULTIMATE RUNNING BOARD REPLACEMENT INSERT. Call or pm if you need further assistance on the replacement. Molly at the toll free order number will help you but you'll need a return auth code for the %60 replacement cost deal.
