The Zoomies = Pipe Surge
The Zoomies is one Tough problem to figure out for tuners regardless of their experiences in clutching and especially tough when a novice tuner has encountered this. After seeing this pipe surge event and figuring it out, you can hear symptoms from other sleds and quickly figure out the problem.
Example:
A tuner builds a clutch setup on an engine that happens to have 125 lbs compression. With 17 grams installed on the primary lever, the sled performs very well, good acceleration and backshift response.
The tuner's buddy has the same sled however that engine has 155 lbs. They install the same parts in this 155 lbs sled and there are problems.
***NOTE - The tuner does not know the compression of Buddy's sled is 155 lbs.***
Buddy runs his sled along at 3/4 throttle and maintains 8000-8100 rpm. When throttle pressed 100%, the engine rpm drops to 7500 rpm. Reduce throttle to 4/5th and the engine wakes back up to 8000-8100 rpms. Throttle pressed 100%, the engine rpm drops to 7500 rpm; Let off the throttle slowly to about 4/5th~3/4 throttle and the engine wakes back up to 8000-8100 rpms.
What...the...hell...is...going on?!!! After many questions, the tuner eventually gets around to asking Buddy what is the engine compression? Buddy says "155", Tuner replies 155???...Wow!
The tuner having experience with high compression engines run on race fuel, knowing what an engine sounds like if it is not loaded enough, asks..."Did the engine make a sound like "RAH RAH RAH" in a very quick repetition, surging quickly?
Did you notice the tach needle bounced up as you held the throttle pressed 100%; the sled surges while trying to accelerate?
.....take note on one of the best elements that reveal pipe surge is the 4/5th throttle test. IF the rpms raise when going 4/5th throttle, and rpms lower and surge when 100% throttle, (this is a dynamite effect to be able to chase down a pipe surge problem). Then the flyweight is not heavy enough for the timing of the engine and the compression of the head to heat the exhaust pipe properly.
Buddy replies "You are explaining perfectly". Buddy being kind of a newbie to the sport has never experienced this condition of Pipe Surge. So I have to say the way it run, he must have thought..."What kind of junk setup did my tuner friend give me?" HAHAHAHAHA
The tuner states this condition was called "Pipe surge" otherwise known as "The Zoomies", "Rah Rah's" or "Wack off's".
Further explanation revealed that the testing was done with engines that had compression of 125 to 132 lbs and that they all took flyweight in the range of 16 to 18 total grams of pin weight.
The Zoomies are caused from the exhaust pipe not heating up quick enough to produce power at proper rpms.
Few ways to get rid of "The Zoomies".
1] Lower the engine compression.
2] Add flyweight to load the engine more.
3] Retard the timing to heat the exh. pipe quicker.
4] Larger start angle on the helix at the start of the shift.
Easiest is to opt for #2 [Add flyweight to load engine more, making the primary push harder]
Tuner's conversation to Buddy:
Add flyweight to 19 grams on the levers and check rpms from there. If you need to add more flyweight to get 8000, then do so. If 19 grams is too much, then less flyweight. Do a MPH check. Try to go wide open and safely achieve top speed to check the flyweight for your 8000 "tach" rpm. If you have too much flyweight, then the engine will start to reduce rpms while full throttle, the rpms will lower at/or near your highest speed. If so, just take a few 10ths of a gram out at a time.
The exercise:
Buddy trial the sled with 19 grams and still had the zoomies. HOWEVER, he lost less rpms.
He would run part throttle at 8000, and then under full throttle the engine would Zoomie at 7700-7800 rpms.
He returned and added 2 grams for a total of 21 grams of flyweight.
Buddy called his tuner pal at work yelling in his ear of how good the sled run. Keeping the clicker the same position all the way thru the exercises, he chose to keep adding the weight to load the engine.
The flyweight loaded the engine hard enough to heat the exhaust pipe while the engine accelerated, the pipe stays hot and the combustion chamber now heats up to make even more power. No more zoomies, now just kicking other sleds butts.
