Wobbly brake rotor
Check the bolt or probably the jackshaft bearing is shot? Take to dealer since under warranty! Mike
Heard a rattling noise under hood narrowed it down to a wobbly brake rotor. Is this normal for a quick drive? If not what needs to be replaced?
Do a search for SW User "Geo" he has dug into this and posted the best write up of this potential problem area and what he found and how he fixed his sled. Good write up and excellent information.
There is a TSB for all 2013 Pro's to address this exact issue. Check with your dealer for all the details.
My 2013 just wiped out the rotor jackshaft bearing.I inspect the q drive bolts and belt before every ride.Noticed belt was not very tight, top pulley bolt was still tight but washer behind it was loose,grabbed brake rotor and it has .5 inch play in it.Took to dealer,they said if jackshaft also damaged from bad bearing they are on backorder.They will not get to it till tuesday and will know more then.What good is the warranty if they dont have replacement parts available?792 miles.
