Will hps can off 11 pro work on 13 pro?
biggdaddy
I have a hps can off of a 2011 pro rmk 800 and want to put it on my 2013 pro rmk 800 just want to make sure it's not a problem. Thanks
Different mounting system, you may be able to order the parts from an 11/12 Pro to make it work.
^^^^^^ This is correct...
The '11/'12 uses a gold color bracket that attaches to the bottom of the bulkhead. You can install this on a '13/'14.
Look at a parts microfiche if you can't compare sleds.
I ran the same hps can on my 12 and 13 model pro rmk it fit fine, but it will push the pipe up and just barely melt the plastic bracket that the exhaust solenoid mounts to. You don't need the gold colered bracket.
