will arctic cat suspension fit apex
Pretty common swap. I have heard that in order for the suspension to be mounted correctly and work right, it needs to be mounted a little high in the tunnel. Not sure if this is true or not. Just make sure mounting holes are in the correct position, an inch off and it will not couple correctly.
I know it is not an apex buy I just put one in my nytro and the mounting points were quite a bit different. I have to mount it about 1.5" forward and up from nytro locations. Works great though
I put a 153" cat skid in my Apex with a 9" big wheel kit and axle. Literally bolted right in. No modifications to the mounting holes at all.
Works great for my application.
The apex and 08-09 nytro's have the same measurment for the suspension holes.
Not shure what other skids will work but the 09 and newer 153 cat skids will boldt right up usuing 9" wheels and a freedom axle only accepting a 162" track.
