I have been playing with my jetting and I think I have found the proper Main for my 04 600 but only one of the cylinders is showing ideal and the other still very rich. Why would my two cylinders be different?
what are the mains you are toying with? and what elevation?
What mains and elevation and are you in ?Powder or hard pack ? We have had a couple of machines get sag in the belly pan by the muffler and so when in powder it start sucking in exhaust fumes and acts all rich and crappy but runs good on hardpack . So we have put in a 90 degree 2" x 2" piece of plastic all the way across the bottom of belly pan ( fastened to plastic from front of tunnel ) Then extended our exhaust pipe 1/2 inch to get the exhaust out a little more . Prob solved so if its doing it in deep powder this could be it
I have tried 400 through 320 at 500-3000 ft. 320 started showing lean on one side and still vey rich on the clutch side, I think 350 will work if I get them burnin the same.
I have been testing in a felid in front of my house, where its been powdery, slushy and now has some tracks in it. Is this problem you speak of with the Jaws pipe models or the quiet pipe models.. They have different cans at the end of the system.
Were you actually fouling plugs because of this?
can you send me a pic of you solution?
Thanks
TonyC
Yes I have a hole in the back but not one on the bottom so when Im in heavy powder the belly pan bottoms out on the exhaust and causes the engine to bog. Does your have a hole on the bottom? Do I cut a new hole?I believe that is normal for the quite pipes to point down , do you have a hole in the back from the jaws pipe ? If so you might want to get a piece of plastic (old truck bedliner works great) and block the extra hole . I'll get a pic for ya soon as i can and get it on here
Skip
you need to cut a hole in the belly pan man. if your pipe dont stick out the bottom get a short piece of exhaust pipe and weld on so it sticks out the bottom a little and cut at a slant. long in front.
