Why won't my sled start.
C
cwh
I recently swapped fuel tanks between my two machines and now my '03 won't run for very long. It seems to be a fuel delivery problem. I can let it idle in the shop for a long time but once its out in the cold with the throttle open it starts to lose power and then dies. If I let it sit I can choke it and get it running long enough to nurse it back to the shop. Any ideas what may have gone wrong. The fuel cap seems to be venting alright and the fuel line in in relatively good shape. What it that device that the fuel tank line plugs into?
Thanks,
Chris
Your fuel line is pinched under the tank.
Pull the extra loop through the left side of the frame so you can see it through the vents in the belly pan, and leave it there problem solved.
Tony
Problem solved alright. I don't know how many times I pulled and drained the tank. At least it doesn't have anymore water or crud in the bottom. Thanks again Tony, your the man.
cwh
i actually talked to tony on the phone today...he IS da man. great guy but i wish he had a few million or so to start the T-Bird or tony eagle or (whatever he might call them) line of snobikes!!!!
