![Face Icon Small Disgusted :face-icon-small-dis :face-icon-small-dis](https://www.snowest.com/forum/images/smilies/old/face-icon-small-disgusted.gif)
Just so I am clear, the clutches are ballanced from the factor with what i would assume would be top of the line technolodgy correct? I have been told that this process is done with no weights or springs in the clutch.
I know i am not the only one the has weighed the weights individually and found them to be off by as much as a gram.
So if we can assume the clutch is ballanced from the factory and we ballance the weights ourselves, shouldn't the clutch be ballanced? And if it is then ballanced, what would make it become unballanced?
I only wonder this because if the factory clutch when assembled with springs and weights is not ballanced(because of the weights being as much as a gram different from each other) it must not make that much difference to the factories specs and therefore not make that much of a difference.
Not trying to ramble just had a thought and was wondering what you all thought.
